1994 Chevy Camaro oil leak
EYKO
  • 1994 CHEVROLET CAMARO
  • V8
  • MANUAL
  • 130,000 MILES
Noticed oil splatters on garage floor after I run the car
had a loose oil cap replaced o ring on filler tube to create seal, drips in 5 spots slowly after car is run then tapers off when cold. Oil pan area and trans are wet
checked plug rear main seal? Timing cover? Oil pan? Help.
Tuesday, August 24th, 2010 AT 9:32 PM
  • 109,885 POSTS
Have you checked the intake gasket, valve covers. What I recommend is to degrease the engine, start it, and then check to see where the oil is coming from.
Let me know what you find.
Tuesday, August 24th, 2010 AT 9:35 PM
