First, is the check engine light on? If so, then start there.
Also, this could be an ignition, fuel or mechanical related issue. (Even a plugged exhaust)
If you haven't performed a tune-up in quite sometime, I'd do this first before diagnosing any problems.
Then check your exhaust for a restriction (Converter), since this is relatively easy. (Plug a pressure gauge into the 02 sensor bung and compare the reading to spec.)
Then check your fuel system beginning with the pump, filter, regulator and injectors.
SPONSORED LINKS
Wednesday, January 20th, 2010 AT 9:25 AM
