1989 Chevy Camaro tbi not pulsing
1989 CHEVROLET CAMARO
145,000 MILES • V8 • 2WD • AUTOMATIC
BIGGD4355
I have constant power to my injectors but have no grounding pulse from the ecm.The color codes from my hanes book don't match the ecm.I replaced the icm about a month ago. The car just died at a stop sign.No spark and no fuel. The new icm fixed the spark problem. I also replaced the ecm a month ago.Any ideas what would cause the icm to go out and the pulse problem for the injector problem?
Sep 4, 2010 at 11:28 AM
JDL
  • 16,098 POSTS
Right now, you do have spark at the plugs? Any applicable trouble codes? If the computer doesn't see an rpm signal, there won't be an injector pulse. The purple wire with white tracer carries the rpm signal from ignition module to computer, no signal no injector pulse.
For distributor, the rpm signal comes from the pickup coil to ignition module to computer. If there was a problem that caused the old ecm to go bad, if you didn't fix it, it may cause problems with the new ecm?
Sep 5, 2010 at 7:21 AM
BIGGD4355
To JDL, I have excellent spark to the plugs. I can put a little gas in the throttle body and it will run til that fuel is gone.I just had the new icm tested and it tested good.I have continuity from the icm to the ecm but no pulse. If the distributer was bad I wouldn't have spark.Can it be a bad second ecm?
Sep 5, 2010 at 8:24 AM
JDL
  • 16,098 POSTS
Any applicable trouble codes? You have 2.8L? Do an ohms test on injector/s.
If you have a digital multimeter that has a tach--duty cycle or dwell setting any of those settings should react to a dc pulse. Check the purple wire with white tracer, engine cranking. My info says the voltage is around 1.6 volts, you should look for a pulse.
I haven't had good experiences with autostore testing parts. I probably only remember the times they were wrong?
Sep 6, 2010 at 3:19 AM
