1989 Chevy Camaro tps volts?
CRAZY)_YANKEE626
Electrical problem
1989 Chevy Camaro V8 Two Wheel Drive Manual
what should the tps volts be on a 89 iroc- camaro with a 5 speed and a tpi motor? and if tps was bad would it stop the pulse to the injectors.
Mar 3, 2010 at 1:18 PM
LEGITIMATE007
  • 5,121 POSTS
all sensors are run on a 5volt reference, , so it could be anywhere from 0 to 5. depending on where your foot is on the throttle. if it is faulty the ecm wont be able to send the right command to the injectors,
Mar 3, 2010 at 1:43 PM
