1980 Chevy Camaro carbutrator
KALEBJSKI
  • 1980 CHEVROLET CAMARO
  • V8
  • 4,000 MILES
I have a holly 750 dbl pump carburator. I seem to be having a problem with the inlet needle! It spews gas out of only one of the two inlet needles. Not a leak it spews out of the top of the carb. What might be ther problem?
Thanks, Kaleb
Monday, February 16th, 2009 AT 4:07 PM
RACEFAN966
  • 5,029 POSTS
I would say that other is pluged and needs to be cleaned out. It will need to be removed to see if you can run a welding tip cleaner rod up through it. Then spray it really good with carb cleaner and air and that should do it.
Monday, February 16th, 2009 AT 9:36 PM
