1969 Chevy Camaro 1969 camrao not starting
CGALLO30
  • 1969 CHEVROLET CAMARO
Engine Mechanical problem
1969 Chevy Camaro V8 Two Wheel Drive Automatic
Hello, I'm working on a 69 camaro, and the car will not start. The car was running good. I have replaced the spark plug wires, rotor, elec. Spark control module, and the disturbutor. The rotor turns when trying to start it, so I think the timing should be ok, the car has a mallory master coil, mallory control module and a new accer wires. What else could the problem be. How could I test the master coil.
Thanks
Tuesday, August 11th, 2009 AT 2:08 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you checked for spark at plugs? Hold plug wire 1/4 in. From block crank sparK. Was it running before all the ign parts?
Tuesday, August 11th, 2009 AT 2:44 PM
CGALLO30
  • 9 POSTS
Yes, the spark plugs are new, but no fire coming outof them. The car was running before the parts were installed but it was already hesitating to start it was turning off. It is getting gas becuase I smell it.
Tuesday, August 11th, 2009 AT 3:14 PM
DOCFIXIT
  • 18,828 POSTS
O.K. Pull coil wire out of cap crank spark. Are you positive distributor is in correctly? Use a volt meter chek voltage at coil, ign module.
Tuesday, August 11th, 2009 AT 3:40 PM
CGALLO30
  • 9 POSTS
Promblem was fixed it turn out to be a pick up coil inside the disturbutor it was not the right one.
Thank you for your help
Monday, August 17th, 2009 AT 10:52 AM
DOCFIXIT
  • 18,828 POSTS
Excellent news now you can go cruising
Monday, August 17th, 2009 AT 10:56 AM
Related Engine Not Running Content
