HELP - nothing is wrong with my Blazer
ANNIEG
I drive a 1994 S-10 Blazer with 160,000 miles. For several months now the car sputters at stoplights and occasionally dies. If you give it gas the sputtering stops. If it dies it always cranks again. I have been to 3 mechanics and all have told me, "There is nothing wrong with your car." We tuned it up - new spark plugs and wires, cleaned throttle body, etc. . . One mechanic said it was just bad gas, but we have filled the tank plenty of times and gas does not make a difference. We also replaced the fuel filter. Since there was "nothing wrong" I continued to drive it. Then, yesterday, when I stopped in my driveway, the car started sputtering and shivering; almost coughing. And the smell- UGH! It is horrible - it almost smells like burning plastic, but not quite. I am clueless as to what is going on with my car. But I am not convinced it is "nothing".
I have had no problems whatsoever with the Blazer cranking. It starts up beautifully every time - even when it's chilly.
Yesterday while it was running I did notice something dripping from the exhaut pipe once the car warmed up. Also, I've noticed that the crazy sputtering and horrible smell only happen once the engine has warmed up.
Oct 3, 2007 at 12:33 AM
SERVICE WRITER
  • 9,123 POSTS
Obviously there is something wrong. My guess is you have a 4.3 motor. These had problems with the fuel injection system and the fuel pumps. I would start by monitoring the fuel pressure, if ok, then I would keep the gauge hooked up and check it while the problem is happening.
Have you had any long cranking situations from a cold start?
Oct 3, 2007 at 12:39 AM
DENNYP
  • 1,824 POSTS
[quote:7335efa858="Service Writer"]Obviously there is something wrong. My guess is you have a 4.3 motor. These had problems with the fuel injection system and the fuel pumps. I would start by monitoring the fuel pressure, if ok, then I would keep the gauge hooked up and check it while the problem is happening.
Have you had any long cranking situations from a cold start?[/quote:7335efa858]also check for black smoke from the tailpipe.this would be a sign of overfueling from a leaking pressure regulator or injector.
Oct 3, 2007 at 3:01 PM
GM2MOM
  • 11 POSTS
may want to check the o2 sensor and the knock sensor if black smoke from tailpipe.
Nov 29, 2010 at 8:25 AM
