1997 Chevy Blazer Idle Misfire
Suggested Repair
Because a flashing check engine light can damage the catalytic converter, tap the converter and replace it if it rattles internally. Plugs, wires, cap, and rotor were already replaced, so clean or replace a sticking EGR valve and gasket, and inspect the spider injector assembly and fuel pressure regulator for leaks that can cause a cylinder 3 or random misfire.
Conversation Summary
A 1997 Chevrolet Blazer with a 4.3L Vortec chugs at idle around 500-600 rpm, sometimes stalls, and shows a flashing check engine light with a cylinder 3 or random misfire. The brake pedal can also become stiff after stopping. Cap, rotor, plugs, wires, and vacuum lines were already checked or replaced. Replies advise checking the converter for internal rattling, cleaning or replacing a carbon-clogged EGR valve, and inspecting the leak-prone spider injector and fuel pressure regulator.
