How do I remove the rear axle C-clamp on a 97 blazer w/locking diff.
Nov 5, 2007 at 1:11 AM
Raise the truck, remove the rear differential cover, and drain the fluid. Position the differential so the C-clips are visible, remove the center pin bolt, then pull each axle inward and remove the clips with a small magnet or pick.
The owner of a 1997 Chevrolet Blazer with a locking differential asked how to remove the rear axle C-clips. The expert advised raising the truck, removing the differential cover and draining it, removing the center pin bolt, rolling the differential to expose the clips, pulling the axles inward, and removing the clips with a magnet or pick.
