Chevrolet Blazer Spark Plug Removal
CHEVROLET
DALEHILL
I have never changed the spark plugs on s-10 blazer 6 cyclinder 2 wd. Should I expect any difficulty? Shoudl I use anti sieize on the new plugs?
Dec 31, 2006 at 6:09 AM
SERVICE WRITER
  • 9,123 POSTS
Use dielectric grease on the inside of the spark plug wires, Lightly coat the plugs with anti-seize, Double check for the correct application of the plugs.
There is one plug that is a mother on the driver's side. Bring your patient side with you on that one, The steering column is right in front of it.
Second I have had very good luck changing the plugs out by loosening the lugs on the two front wheels then jack the car up and put it on jack stands, then take one tire at a time off and you can gain access to the three plugs on that side through the inner fender well opening. Then do the same to the other side. It is much easier that doing it from above.
Dec 31, 2006 at 9:41 AM
Suggested Repair
Lightly coat the new plugs with anti-seize, apply dielectric grease inside the plug wires, and confirm the plugs are the correct application. The driver's-side plug near the steering column is tight; for easier access, support the vehicle on jack stands, remove one front wheel at a time, and reach the plugs through the inner fender well.
Conversation Summary
The owner of a Chevrolet S-10 Blazer 6-cylinder 2WD asked whether spark plug replacement would be difficult and whether anti-seize should be used. The expert recommended light anti-seize on the plugs, dielectric grease inside the wires, and verifying the correct plugs. One driver's-side plug is hard to reach because of the steering column; removing the front wheels and working through the inner fender wells was suggested as an easier method.
