1986 Chevy S10 Blazer High Idle
GREGGERYPK
i have a 86 chevy s10 blazer with a 2.8 liter, and wen i start it, it idles high and does not go down, i don't think its the weather because the weathers nice her just a little rainy and i've changed the map sensor and mass air flow sensor????can you please help me????thank you
Sep 30, 2007 at 1:14 PM
DENNYP
  • 1,824 POSTS
[quote:9a4f6ecdb0="greggerypk"]i have a 86 chevy s10 blazer with a 2.8 liter, and wen i start it, it idles high and does not go down, i don't think its the weather because the weathers nice her just a little rainy and i've changed the map sensor and mass air flow sensor????can you please help me????thank you[/quote:9a4f6ecdb0]check the IAC valve in the throttle body.
Sep 30, 2007 at 2:57 PM
Suggested Repair
Check the idle air control (IAC) valve in the throttle body.
Conversation Summary
The owner of a 1986 Chevrolet S10 Blazer with a 2.8L engine reports that it idles high after starting and does not come down. The MAP and mass airflow sensors were already replaced. The expert advises checking the IAC valve in the throttle body.
