1989 Chevy S-10 Blazer No Start
FUTUL2E_MARINE
  • 9 POSTS
I Have a 1989 Chevy S-10 Blazer 4WD, it has not been driven in about a year, I'm almost 16 so the SUV was given to me, It used to start when I turned the ignition on, but now it wont, I have changed the battery, and it trys to turn over but it wont seem to start..it ONLY starts if i spray 2+2 Gum Cutter into the Carborator...Any help ?
Oct 29, 2007 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
89 is fuel injected.When you first turnon the key do you hear the fuel pump run? The pump might have been borderline before the truck was stored, and now it is locked up. Check if the pump runs and get back to me
Jan 29, 2021 at 6:08 AM
FUTUL2E_MARINE
  • 9 POSTS
I dont think it does, my uncle is a Mechanic and he tryed listening for it and i dont think he heard anything, he thinks its the fuel pump, but the fuel pump i need is in the gas tank and they are like 300 bucks. im just trying to get a 2nd opinion before i go out and get a new part like that.
2CARPRO JACK
  • 11,533 POSTS
It is an 89 and not a 98 correct? The fuel pump for a 89 is only 100.00 ,A/C Delco p/n EP386, the strainer is 8.91 A/C p/n TS4, the relay is 13.05, A/C p/n 12-2371. You should be good for well under 200 bucks
FUTUL2E_MARINE
  • 9 POSTS
yes an 89. ok good, i was just checking for a fuel pump on autopartswarehouse.com and they have them for like 50/60 bucks. thanks.
FUTUL2E_MARINE
  • 9 POSTS
I also got another question, since its an old truck, the turn signal/wind shield wiper "switch/stick" is broken and someone taped it back on, is this replaceable, cuss it doesn't look like it, and if so can you give me any sites/stores that may have this part..thanks.
2CARPRO JACK
  • 11,533 POSTS
Dealer item, but just the "wand" is available.Pops in and out. BTW... careful where you buy your pump, had a cust buy one online (the real $500 model) trying to save a few bucks, it didnt put out enough pressure and we had to remove the tank a second time (on him) and put a A/C Delco in it, ran perfect. Also, if your pump unit has a "pulse dampener" between the pump and the tank unit, remove it and round file it, they caused alot of weird problems, and if you buy a quality pump it will have a piece of FI hose to put in its place
FUTUL2E_MARINE
  • 9 POSTS
alright, thanks..Appreciate it, Ive been trying to find help on this issue for awhile, and finally!, lol..thanks again.
2CARPRO JACK
  • 11,533 POSTS
N/P
FUTUL2E_MARINE
  • 9 POSTS
ok, I just thought about somthing, If the fuel pump wasnt working, there wouldnt be no gas in the line going to the carborator, right? I just took my carb apart and took off the gas line where it connected to the carb and there was some gas that came out. or do u think my line might be clogged ?
2CARPRO JACK
  • 11,533 POSTS
That isnt a carb, an 89 should be TBI injection. The pump san push a small amount of fuel, but it has to be under pressure for everything to work properly
FUTUL2E_MARINE
  • 9 POSTS
oh ok, so it is the pump, thanks. lol.
FUTUL2E_MARINE
  • 9 POSTS
So If i go into Advance Auto Parts and just tell them i need a fuel pump for an 89' chevy s-10 blazer, will they find it for me or do i gotta tell them more ? like the filter size and everything.
RAYT333
  • 27 POSTS
You only need to tell them what it is for and they shoulod be able to give you the correct pump.
Now as to actually replacing the pump, it is a big job to drop the gas tank and replace the pump. I have done this several times and now I take a shortcut when working on these older blazers, now I pull up the carpet in the rear and cut a hole in the floor, about a foot square and you can reach in and disconnect the lines and remove the pump much easier and faster. I cut a piece of metal about 2 inches bigger then the hole and put it over the hole and replace the carpet. I haven't ever had a problem doing it this way, the factory should have put an access door there in the first place.
FUTUL2E_MARINE
  • 9 POSTS
ok, I didnt know it was that complicated, lol..i thought just unscrewing a couple bolts wld drop the tank, i guess ill have my uncle put it in for me. appreciate it.
Suggested Repair
Confirm the in-tank fuel pump runs when the key is first turned on. For this 1989 TBI truck, replace the pump with a quality AC Delco unit (p/n EP386), plus strainer TS4 and relay 12-2371 if needed. Residual fuel in the line does not mean there is enough pressure. Avoid cheap pumps that may not build pressure. If the pump assembly has a pulse dampener, remove it and replace it with the fuel-injection hose supplied with a quality pump. The turn-signal/wiper wand is a dealer item that pops in and out.
Conversation Summary
A 1989 Chevy S-10 Blazer 4WD that sat about a year cranks but will not start unless starting fluid is sprayed into the intake. The owner replaced the battery and thought it had a carburetor. The expert said an 1989 uses TBI injection, asked whether the fuel pump runs at key-on, and recommended an AC Delco in-tank pump, strainer, and relay for well under $200, warning that cheap pumps may not make enough pressure. The owner later found some fuel in the line; the expert explained residual fuel is not the same as proper pressure. A second reply noted the tank must be dropped to replace the pump and described cutting a floor access hole as a personal shortcut. The owner planned to have a mechanic install the pump. The broken turn-signal/wiper wand was identified as a replaceable dealer part.
