You sked if I had tried starting fluid. Was told that wa a big NO NO. Give it a try?
Monday, March 22nd, 2010 AT 7:53 AM
TOOOMANYTOYS
MECHANIC
If you are trying to determine if its a fuel related concern yes a small amount if starter fluid is ok. People say not to use starting fluid on a regular basis. Prolonged use can cause piston and cylinder wall damage.
SPONSORED LINKS
Friday, January 29th, 2021 AT 11:48 AM
DNANTZUSN
MEMBER
Tried the starting fluid and still FUBAR, had friend over and I got under fuel tank while he turned key. Fuel Pump engages. Like I said, FUBAR!
TOOOMANYTOYS
MECHANIC
If it will not run on starter fluid, and the engine sounds like its got good compression. The next step would be to check for spark. Blazers have a common problem getting water in the distributor. You can get a spark tester at most autoparts stores.
DNANTZUSN
MEMBER
Someone else told me to check the distributor cap for cracks too. Is it just a moisture thing or water bypassing the rubberer seal? Wonder if I should make and screw a cover plate over the distibutor and screw it to the firewall? Please let me know, it rained and won't start again. Thanks much Dnantzusn retired.
TOOOMANYTOYS
MECHANIC
You could try that but first make sure that it is spark that is the issue. Repair failed part. Then add a water shield, or distributor jacket
SPONSORED LINKS
DNANTZUSN
MEMBER
Much thanks Partna! Got to wait to get it started again now to get to Advance Auto.
