2001 Chevy Blazer car will not start
LIEVFAM4
  • 2001 CHEVROLET BLAZER
  • 6 CYL
  • 12,400 MILES
Car will not start, battery is fine fuel pump is working what else could be wrong
Sunday, April 26th, 2009 AT 12:41 AM
What is it doing? Cranking over and refuses to start or just won't crank over at all/nothing?
Sunday, April 26th, 2009 AT 12:46 AM
LIEVFAM4
Car is cranking over but will not start
Sunday, April 26th, 2009 AT 12:49 AM
Get helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, April 26th, 2009 AT 6:58 AM
2NYCE
It could be fuel pump get some starting fluid and pour some intake have someone to turn ignition if it starts up a fuel pump
Monday, April 27th, 2009 AT 7:22 AM
