2001 Chevy Blazer Wheel noise
2001 CHEVROLET BLAZER
BIGSPRTSBEN
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic
In my Blazer i just change the back 2 rotors and brakes but now the front left is makeing bad noises whenever i drive at first it was when i turned but now it is all the time so i thionk it is either the Wheel bearing going bad or the tie rod. so if somebody could help it would be greatly appreciated
Dec 23, 2008 at 2:06 PM
MIKE H R
  • 3,094 POSTS
Without me hearing the blazer or knowing what noise is , I would first check the front brakes. Then check the bearings. jack up the vehicle where the left wheel {on making the noise} up and wiggle the wheel beck and forth, then up and down. you should be ablre to find out where the noise is comming from .
Dec 24, 2008 at 10:25 AM
