have no power steering?
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
RIDDLEBOX53204
  • 5 POSTS
I got into my truck tonight and had no power steering. I drove it yesterday and it was perfect. There was no fluid dripping, the fluid level was fine, and the serpentine belt is fine. Is it the pump itself or could there be another part I should check?
Dec 16, 2007 at 4:38 PM
DENNYP
  • 1,824 POSTS
remove the belt and inspect the pwr steering pump for a broken pump shaft.
Dec 18, 2007 at 1:21 PM
  • 55,649 POSTS
This can be either the pump or the steering box, remove the pump cap and start the engine , you if don't see fluid circulating the pump is bad, and if the fluid is moving the box is bad, this guide can help
https://www.2carpros.com/articles/power-steering-problems
Please go over this guide and get back to us.
Dec 2, 2024 at 6:09 AM
