Engine Performance problem
2001 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I ran out of fuel and was given a can that also had water in it. I removed tank drained replaced put good fuel in and some water remover. Is there anything else that I should do to get it started? Do the injectors need to be cleared? It stile does not start, should I just be persistent?
Mar 17, 2009 at 6:27 AM
