Engine Performance problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 120.00 miles
can any one help i am my wits end a bought a 1995 s-1o blazer i was told it only needed a egr valve after buying it realized he broke the bolt hole thats holds egr , so replaced intake all new gaskets .done right .wrong poured black smoke, tour it back down replaced fuel regerular, great black smoke stopped. now you start it will idle proplerly after a minute or so give it gas takes another minute or so refore it idles properly again does not seem to mis on idle seems to stumble on the way back down to idle. toke it for a small drive has no power on hills also no check engine light on. heres a list of what has replaced intake,gaskets.egr.fuel pump.fuel tank.gas lines and rear hoses,spark plugs ,map sensor.any guesses i am stumped thanks peter
Aug 21, 2008 at 9:28 AM
