2001 Chevy Blazer engine ligth
91,000 MILES • 6 CYL • FWD • AUTOMATIC
FAST_BLUE_CAR
  • 7 POSTS
my engine light is flashing when im driving at speeds of 60 + mph?
Jul 22, 2009 at 2:37 PM
LEGITIMATE007
  • 5,121 POSTS
if thats happening then a fault code must be set, bring your vehicle to autozone for a free computer scan, bring the codes back to me for diagnosis.
Jul 22, 2009 at 3:24 PM
FAST_BLUE_CAR
  • 7 POSTS
[quote:4531ea242b="legitimate007"]if thats happening then a fault code must be set, bring your vehicle to autozone for a free computer scan, bring the codes back to me for diagnosis.[/quote:4531ea242b]
the code is p0304
Jul 23, 2009 at 9:07 AM
LEGITIMATE007
  • 5,121 POSTS
ok , that is cylinder four misfire, start by checking spark plugs, specifically number four cylinder, but if your gonna change it you might as well change them all, check the wires, that cylinder wire could be arcing against the block too . you want to feel the wire, do like a little bending of the wire to see if there is actually a bad corrosion inside the center of the wire. get back to me with your findings,
Jul 23, 2009 at 2:21 PM
FAST_BLUE_CAR
  • 7 POSTS
[quote:61cc38587f="legitimate007"]ok , that is cylinder four misfire, start by checking spark plugs, specifically number four cylinder, but if your gonna change it you might as well change them all, check the wires, that cylinder wire could be arcing against the block too . you want to feel the wire, do like a little bending of the wire to see if there is actually a bad corrosion inside the center of the wire. get back to me with your findings,[/quote:61cc38587f]
I had replaced all the spark plugs and wire, and cap ect.
Jul 23, 2009 at 3:13 PM
LEGITIMATE007
  • 5,121 POSTS
how does cylinder four spark plug look? gas , oil on it?
Jul 23, 2009 at 3:17 PM
FAST_BLUE_CAR
  • 7 POSTS
[quote:3de590a424="legitimate007"]how does cylinder four spark plug look? gas , oil on it?[/quote:3de590a424]
It's look's fine..
Jul 24, 2009 at 5:55 AM
LEGITIMATE007
  • 5,121 POSTS
next check ./clean the mass airflow sensor, and check/change crank position sensor
Jul 24, 2009 at 3:24 PM
FAST_BLUE_CAR
  • 7 POSTS
[quote:b4bcd0ff84="legitimate007"]next check ./clean the mass airflow sensor, and check/change crank position sensor[/quote:b4bcd0ff84]
everthing looks fine.
Jul 25, 2009 at 3:56 AM
