2000 Chevy Blazer The gas is not reaching the engine
RYANNSLLS
MEMBER
2000 CHEVROLET BLAZER
Engine Mechanical problem
2000 Chevy Blazer 6 cyl Two Wheel Drive Automatic
Please help
Wednesday, September 23rd, 2009 AT 7:22 PM
MECHANIC
Have you checked to see if the fuel pump is working and the filter isn't plugged?
SPONSORED LINKS
Monday, October 19th, 2009 AT 10:44 AM
GPMONSTER
MEMBER
Hey ill tell you this the fuel pump is bad have a mechanic test it takes 5 min hee will tell you the pump is bad chevys pump on that vehicle shorts out replace it and check the fuel relay as well good luck
