2001 Chevy Blazer SES Light Out
Thank you for your help and a Happy New Year!! I finally got the opportunity to take the dash apart again today and test the brown and white wire. I get no power when the key is powered on. What is my next step?
[quote:8b8fdfbfbd="2CarPro Jack"]First use a test light or meter to see if the Brown/White wire in slot 2 on the instrument cluster plug gets power with the key on.That way you know for sure the PCM/VCM are trying to light it.Other thab that, you might have to get a reman cluster, some things arent serviceable.[/quote:8b8fdfbfbd]
Suggested Repair
Check for key-on power on the brown/white wire at instrument cluster connector slot 2. If there is no power, verify continuity from that wire to the PCM at the right front of the engine compartment. With continuity present and the LED still not lighting when current is applied, suspect both a failed cluster LED and a PCM that is not commanding the lamp. Ask a properly equipped shop to flash the PCM before replacing it, and replace or use a remanufactured cluster if the LED is not serviceable.
Conversation Summary
A 2001 Chevrolet Blazer failed inspection because the Service Engine Soon lamp does not illuminate. The owner removed the instrument cluster and found that the indicator is an LED. Testing showed no key-on power on the brown/white wire at cluster connector slot 2, although continuity from that wire to the PCM was good. Applying current still did not light the LED. The expert said there may be two faults—a damaged LED and a PCM not driving the circuit—and recommended having a shop flash the PCM. The PCM is located at the right front of the engine compartment.
