2000 Chevy Blazer axils?
2000 CHEVROLET BLAZER
THUNDER_WINTER
Shakes or Wobbles problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I want to know if I need to change my ball joints in the front, would it be cheaper and better to change the axils? Does that make any sense?
Dec 1, 2009 at 8:01 AM
SWILLIAMS
  • 597 POSTS
Entirely different parts. There are 4 ball joints. One upper and lower per side. The axle shafts would only need to be replaced if they are bad or the boots were torn/damaged and got dirt in them.
If you're changing the ball joints you may also want to check the idler arm and the rest of the steering linkage as well. remember that once the ball joints are replaced you will need to get the front aligned. That is why it is usually easier to change the idler, ball joints and tie rod ends all at once. But it's your choice.
Dec 4, 2009 at 2:20 PM
