HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Suspension
Ball Joint
Replace/Remove
1989 Chevy Blazer ball joints
DANNY187
MEMBER
1989 CHEVROLET BLAZER
Suspension problem
1989 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how long should it take to replace upper and lower ball joints on both sides
Saturday, January 10th, 2009 AT 6:24 PM
BLUELIGHTNIN6
MECHANIC
For an experienced mechanic, between 4.5 hours and 5 hours, depending on if your vehicle is equipped with a skid plate.
Hope this helps..
Thanks for using 2carpros.com !
Saturday, January 10th, 2009 AT 6:41 PM
Please
login
or
register
to post a reply.
Related Ball Joint Replace/Remove Content
2000 Chevy Blazer Axils?
Shakes Or Wobbles Problem 2000 Chevy Blazer 6 Cyl Four Wheel Drive Automatic I Want To Know If I Need To Change My Ball Joints In The...
Asked by
Thunder_winter
1 ANSWER
2000
CHEVROLET BLAZER
GUIDE
Ball Taper Joint Release
The car must be jacked up off the ground and supported on jack stands. You may need to remove the wheel to be able to access the ball joint more freely. There are two...
1998 Chevrolet Blazer Sway
My Blazer Sways When Its Wet Or I Go Over 60 Mph. It Is Also Eating My Tires Up. Ive Replaced The Ball Joints, Tie Rod Ends, And Cv Axels...
Asked by
mbake23
1 ANSWER
1998
CHEVROLET BLAZER
1995 Chevy Blazer Clanking Sound
Suspension Problem 1995 Chevy Blazer 6 Cyl Four Wheel Drive Automatic Ok This A Hard One To Explain. On Left Hand Turn I Can Hear (...
Asked by
cockroach
1 ANSWER
1995
CHEVROLET BLAZER
2004 Chevy Blazer Abs Light After Ball Joint Repair
So I Just Spent Saturday Morning Replacing All 4 Ball Joints On My 04' Chevy Blazer Zr2. A Buddy And I Took On The Project In An Effort To...
Asked by
dleonfc0
2004
CHEVROLET BLAZER
94 S-10 Blazer 4x4 Making Noises...
Background - I Have A 1994 Chevy S-10 Blazer With 4x4 On The Fly. It Has 233,500 Miles With A 4.3 Turbo Engine. Overall, The Truck Runs...
Asked by
char971
1994
CHEVROLET BLAZER
VIEW MORE
Steering Wheel Shaking
Tie Rod End Replacement
Shock Replacement - Front
