1999 Chevy Blazer What else could it be?
THE MEKANIC
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 118,000 MILES
Friend called, his Blazer would not start. Had spark, no fuel pressure at rail, no audible noise from pump. Pump bench tested dead, so replaced with fresh pump.
Also, new air filter, cap and rotor, and fuel filter.
We have spark at the coil, and spark on the other side of the cap. I have pressure at the fuel rail, and it should run, you would think.
However, it does not.
Any ideas?
Tuesday, December 29th, 2009 AT 12:15 PM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd still have to use a gage and check fuel pressure. On the spider fuel system, the poppets have been known to stick open or closed. The best cleaning procedure is a shop procedure. Injector cleaner in the gas tank my not help anything. I can't be sure that fuel is your problem?
Tuesday, December 29th, 2009 AT 12:35 PM
