I have a 99 blazer and my friend ran it out of gas a week or two ago and now I cant get gas to come to the motor! I changed the fuel filter and still nothing. Does this model have a emergency fuel switch that u have to press if you are in a wreak or run out of gas? Please help me!
SPONSORED LINKS
Tuesday, January 29th, 2008 AT 2:24 AM
MECHANIC
No it doesn't have a fuel cut off switch its not a Ford.
Start by checking the fuel pressure to confirm that the fuel pump is working-Do you hear the pump when you turn key to On?
Tuesday, January 29th, 2008 AT 3:54 AM
ALLGOOD690
MEMBER
No I dont. Does that mean its my fuel pump and I dont have any pressure on the gas lines
SPONSORED LINKS
Tuesday, January 29th, 2008 AT 4:04 AM
MECHANIC
Find the fuel pump connector and check for power there-if its there -the fuel pump when southbound
