1999 Chevy Blazer turns over but wont start
WAP
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 120,000 MILES
I have a 1999 chevy blazer that died while I was driving I replaced the fuel filter distributer cap& rotor checked fuel pressure and I have 10lbs, when I turn the key on you can here the pump come on for a few seconds then shut off. Also it turns over fine just wont start I tried pouring some gas in the throttle body and it started and ran for a few seconds any suggestions?
Thursday, November 6th, 2008 AT 11:26 AM
Type of fuel system: TBI or MPFI-if its a TBI your fuel pressure is okay-MPFI its too low-
You can try checking for injection pulses from the injector/s. No injection-could be the computer ground drivers for the injector/s or power to the injector/s the computer could be missing the ignition reference signal
Thursday, November 6th, 2008 AT 12:11 PM
WAP
Its a csefi system?
Thursday, November 6th, 2008 AT 12:22 PM
The fuel pressure should be 60-66psi
Thursday, November 6th, 2008 AT 12:38 PM
WAP
I have 10lbs pressure should I replace the fuel pump?
Thursday, November 6th, 2008 AT 1:16 PM
Replace the fuel pump
Thursday, November 6th, 2008 AT 1:17 PM
WAP
Thanks for your help!
Thursday, November 6th, 2008 AT 1:20 PM
