Heater no blowing hot?
RIVERMIKERAT
  • 6,110 POSTS
Jessie, it sounds like you have a completely plugged heater core. Does your vehicle have a valve on the heater core supply hose? If so, does the valve move?
Friday, January 3rd, 2020 AT 3:14 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
  • 1998 CHEVROLET BLAZER
  • 89,000 MILES
My 1998 Chevy Envoy heater will only blow cold air. This started est a month ago.
Check thermostat if its stuck open, heater core if its clogged and the air blend door if its stuck in the cold position
JEFROPCI
  • 6 CYL
  • 4WD
  • 49,000 MILES
My heater does not get hot. The temp is 198deg. It has a computer climate control heater.
Can it have a weak water
pump.
MASTERTECHTIM
  • 4,750 POSTS
No weak water pump. Most likely your heater core is restricted due to crud built up in it. Try removing the hoses from your heater core and blow out the heater core. I usually fill the heater core with water and blast compressed air through it. I put a rag at outlet and observe all the crud that comes out. This usually fixes this problem. Remember feedback and votes are appreciated if I have helped you
JNURSE
  • 176,000 MILES
I had heat in my blazer.I had pinhole on heatercore hose.I cut off the bad spot. Hooked hose backup lost heat.I replaced thermostat had radiator flushed still no heat
WRENCHTECH
  • 20,761 POSTS
You probably have air trapped in the heater core. That's why we usually use vacuum to fill the cooling system.
JNURSE
How do I get the airpocket out
WRENCHTECH
  • 20,761 POSTS
It should work out on it's own.
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch.
If you find that they are both too hot to hold, then the heat in that vehicle is controlled by a blend door that regulates heated air flow. It is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
If they are both not too hot to hold on to, then you either have a restricted heater core or the system is not completely full and getting air pockets for some reason.
AMYMT1974
Heater problem
1998 Chevy Blazer Engine Size unknown Four Wheel Drive Automatic 165184 miles
we just changed the thermostat and before we did that the heater was just blowing cold air and then we changed the thermostat and it started working at first but it seems it is only blowing hot air like it should when it is sitting there but when you start driving it blows kinda warm air but mostly cold so what else could it be. We had a new radiator installed about 6 months ago and a new engine so everything has been replaced.
BMRFIXIT
  • 19,053 POSTS
Check and adjust coolant level
try to flush heater core
TIMMAAYY
Heater problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
i just recently did a head job on my blazer. After putting the heads back together the heater does not work. The fan doesn't blow period. If I run the fan directly to the battery it works, sounds fine. Any ideas, I know I could run a 3speed toggle but id rather use the existing system.
BMRFIXIT
  • 19,053 POSTS
When you say direct to battery are you supplying it with power and ground or just power
if just power you should be able to control the speed from the switch and in this case I would suspect a bad fuse ,wire and or relay
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
TIMMAAYY
I supplied both power and ground. Checked all the fuses, inside and under the hood.
BMRFIXIT
  • 19,053 POSTS
What happen if you supply power only or ground only
let me know
TIMMAAYY
Thanks I will in 1 hour I really appreciate your responses.
KILLARB634
  • CHEVROLET BLAZER
1998 Blazer 4wd
123k
automatic
4wd
4dr
Ok the heat in the car does not work. Oil was replaced 2 weeks ago during tuneup. Just started needing the heat and it doesn't work.
The AC blow extremely cold when on. I believe the switch works too because I can set it to auto and it will go on and off at different levels. What is causeing this and how do I fix it?
Thanks
Brian
Thursday, July 16th, 2020 AT 10:28 AM (Merged)
BLACKOP555
  • 10,371 POSTS
Are both the hoses going into the heater core hot to the touch? If both are then check the blend door. If one or none is id bleed the coolant sensor
KILLARB634
Ok, will check hoses tomorrow, what isthe blend door? Is it the piece that sepeartes the hot and cool water in the heater core?
Thanks
RICK390
  • 7 POSTS
He, s right if the hoses are hot then the unit that separates the cold ac air from the hot heater air can become jammed and not move from cold to hot when you turn the temp knob possible causes are, debris down in the heater box such as a straw, tooth pick, pen or pencil, or simply the blend door actuator has failed, if hoses are not hot to touch a simple thermostat could be the culprit, rick
