Heater no blowing hot?
SEABEE26
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 100,000 MILES
I have a 98 Blazer ZR2 and the floor heat has not worked since have owned it. The same goes for A/C as well. When I turn the climate control selector to floor I hear the doors moveing but it just goes to defrost. Are the doors stuck or is the selector malfunctioning?
Friday, January 3rd, 2020 AT 3:13 PM (Merged)
RHALL77
  • 3,361 POSTS
Does it stay on defrost all the time? Do you know if it is automatic temp controls?
SEABEE26
It has manual climate control and defrost works as well as the air on your face. It just goes right to defrost when I select floor
RHALL77
  • 3,361 POSTS
Sounds like a HVAC control unit problem not sending vaccum to the correct actuator. Or you are loosing vaccum at the actuator.
DEBMOWAT
I have the same problem with my 97' blazer! Defrost only for all heat and a/c settings. If it might be the HVAC conrtol unit or the actuator, where are they located on the vehicle, and can you fix them yourself, test, replace, get used at wreckers?
RHALL77
  • 3,361 POSTS
If your not sure how to test it, I would suggest going to a junk yard and getting a new HVAC control and seeing if it works.
RDKRAFT
Heater problem
1998 Chevy Blazer 6 cyl Four Wheel Drive
i have a 1998 chevy blazer one heater hose gets hot the other stays cold is ther a valve or what controls the water flow or what could be wrong we have changed the thermostate
  • 109,779 POSTS
Hi:
It could be the heater control valve or the heater core could be plugged not allowing coolant to circulate.
Friday, January 3rd, 2020 AT 3:14 PM (Merged)
TOMMYL
  • 6 CYL
  • 4WD
  • 151,000 MILES
When driving, the engine temperature rises relatively quickly to around 190 then drops, rises again then drops. All the while, my heater blows cold air. Is the engine thermostat accessible to the average backyard mechanic? I live in Michigan and the temperature is dropping into the 30's at night already. I have not detected any heater core leak, at least not inside the truck. Thanks for any help you can give.
  • 109,779 POSTS
Yes the t-stat is easy to replace. However, before you do that, check something for me. If you are getting no heat at all, first make sure the coolant level is full. Next, with the engine running, hot, and the heater on high, feel both heater core hoses. Both should be hot.
Let me know what you find.
WILLIAM_UNGER
  • 6 CYL
  • 175,000 MILES
I have completely scoured the radiator and coolant system looking for problems. I have found none. I am starting to think about the coolant temp sensor is shot. We are not getting any heat inside the vehicle.
Did you check the thermostat and heater core. The coolant temperature sensor's job is to sense the engine temperature and the thermostat controls the temperature
JILEZ069
  • 4WD
  • 289,333 MILES
I just changed the blower motor yesterday cause I thought that was the problem but its not I still get no air on 1, 2, 3, or 4 what could be the reason for this
CJ MEDEVAC II
  • 222 POSTS
See my link
Http://shop.advanceautoparts.com/p/bwd-hvac-blower-motor-resistor-ru1027/20972204-p?navigationpath=l1*14922%7cl2*15019%7cl3*15900
Look at the connections to it also, they might be melted/ deformed from excessive heat (which might be the entire problem, and not the resistor). The connectors are probably available too from the auto parts stores
Let us know how things are working out
The medic
JILEZ069
Thanks
JILEZ069
I have heat on fan speed three now, but my speedometer is now stuck at 180 top speed
BOLT1234
  • 6 CYL
  • 185,000 MILES
I have a 1998 s10 blazer and it has no heat I changed t-stat and flush radiator how do I bipass control valve?
  • 109,779 POSTS
To the best of my knowledge, it doesn't have a heater control valve. If it does, it would be on the supply side heater hose. If nothing is there, then you have a blend door that determines if you get heat. What I need to know is this, have you tried flushing the heater core as well as reveres flushing? Next, with the engine hot, heat on high, do both heater core hoses get hot?
CARADIODOC
  • 33,881 POSTS
Hey guys. Take a look at the speedometer pointer to see if there's a little stop peg the needle is against. By the late '80s / early '90s everyone went away from the too-reliable cable-driven speedometers and switched to electronic ones driven by a not-so-reliable computer. Turns out they have been rather trouble-free, but what can happen is they get hit with a voltage spike during other electrical repair work. This happens most commonly when connecting a new battery.
The speedometer is driven by a "stepper" motor. It is not a spinning motor with brushes like we normally think of. A stepper motor has four electromagnetic coils that are pulsed with varying voltage and polarity to create a movable magnetic field for the pointer to follow. You can identify these by the fact that they stay where they are when the ignition switch is turned off. They don't go back to "0" until the ignition switch is turned on next time.
The problem with those voltage spikes is if it causes the pointer to go more than halfway to maximum, when the ignition switch is turned on next time, it wants to go back to "0", but it looks for the shortest way to get there, and that will be clockwise. The pointer runs up against the stop pin and can't go any further.
There's three ways to fix this. The hardest method is to disassemble the instrument cluster to the point you can push the pointer counter-clockwise by hand. An easier method is to connect a scanner that can access the instrument cluster, and run the gauge test sequence. Typically that positions every gauge to its 1/4 scale, 1/2 scale, 3/4 scale, full scale, then back to "0". The speedometer will try to follow those steps, and once moving counter-clockwise is the shortest way to the target, the pointer will go there, then follow all the other gauges back down. Some cars can have the gauge test sequence initiated by pressing certain buttons in the right order without the need for a scanner.
The easiest method is to simply drive the vehicle faster than half the maximum speedometer scale. That doesn't mean 90 mph. Speedometer faces never have "0" and the highest number in the same place. Typically 0 to 180 will cover perhaps 270 degrees of sweep. In my minivan the highest reading is 125 mph, and 45 mph is right across from it. "80" is across from "0", so according to my sad story, if the pointer got stuck on the backside of the stop peg, I'd have to go 81 mph, then the shortest way to the target for the pointer would be to go counter-clockwise, then from there it would follow the computer back to its commanded positions.
Sorry that I don't do a good job of describing this fix. It's much easier to do than to explain it.
JESSIEBAIN72
I have the exact same problem and neither of the hoses get hot.
