1995 Chevy Blazer oil in radiator
1995 CHEVROLET BLAZER
169,000 MILES • 6 CYL • 4WD • AUTOMATIC
EXCALIBER01
i took my blazer to mechanic radiator leaking water-and running really rough -he replaced radiator- plug and said was running smooth-drove home 1 mile ran fine -drove to work next day 12 miles running rough as in repping up would not idle down- drove home- checked water in refill tank real brownish oily-took baster got out oily gook thinking they didn't flush out lines when put in new radiator-checked oil and transmission fluids both are full-scared to start it up noticed on one comment about bubbling noise behind dash maybe head gasket blown-i have heard noise for about year now - when had oil changed last asked man he said that is normal??? broen gook in radiator any suggestions and est. cost to repair thanks linda
Jun 8, 2008 at 6:20 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9cfac38c75="excaliber01"]Engine Performance problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 169000 miles
i took my blazer to mechanic radiator leaking water-and running really rough -he replaced radiator- plug and said was running smooth-drove home 1 mile ran fine -drove to work next day 12 miles running rough as in repping up would not idle down- drove home- checked water in refill tank real brownish oily-took baster got out oily gook thinking they didn't flush out lines when put in new radiator-checked oil and transmission fluids both are full-scared to start it up noticed on one comment about bubbling noise behind dash maybe head gasket blown-i have heard noise for about year now - when had oil changed last asked man he said that is normal??? broen gook in radiator any suggestions and est. cost to repair thanks linda[/quote:9cfac38c75]
Ok, When you checked the Oil was it a milky color or frothy? if it was then it probably has water in it and since oil floats on top of water it would look full.
It does sound like a Blown Head Gasket and you are looking at a cost of anywere between $1,500 and $2,000 at a local garage.
post responses here in forum.....
Jun 8, 2008 at 1:10 PM
