HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Engine
Symptoms
Not Running
SPONSORED LINKS
1993 Chevy Blazer no start
REBEL300
MEMBER
1993 CHEVROLET BLAZER
Engine Mechanical problem
1993 Chevy Blazer 6 cyl Two Wheel Drive Automatic
truck had no fuel pressure so replaced fuel pump. It has 20 pounds of fuel pressure now and still wont start, no leak in the spider. Any suggestion.
Thursday, January 29th, 2009 AT 11:58 PM
RHALL77
MECHANIC
Check your fuel filter and see if it is plugged. Also look at your fuel line and see if there is a restriction
SPONSORED LINKS
Friday, January 30th, 2009 AT 7:49 AM
REBEL300
MEMBER
Already replaced fuel filter quess you didnt see I said it had good fuel pressure to shrader valve
Friday, January 30th, 2009 AT 6:16 PM
RHALL77
MECHANIC
Your pressure could be fine. Its volume im wondering about.
Monday, February 2nd, 2009 AT 2:05 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1993 Chevy Blazer Will Not Start But Will Start With...
I Have Replaced The Throttle Body Sensor, Check Fuel Pressure. The Car Will Not Start, But If I Use Starter Fluid It Will Start. If We...
Asked by
mike0709
1993
CHEVROLET BLAZER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1993 Chevy Blazer It Will Not Start 4.3l
I Have A 1993 Chevy Blazer That Has A 4.3l Vortce Two Wheel Drive And It Is A 4.3l W And It Got Spark And Good Gas Presure And It Will Not...
Asked by
lowrider9307
1993
CHEVROLET BLAZER
1993 Chevy Blazer Wont Start
Have Done A Complete Tuneup Changed Fuel Pump Filter. Car Runs For A Few Days But Shutit Off Wont Start Back
Asked by
hardtimes395
1993
CHEVROLET BLAZER
1993 Chevy Blazer No Start Problem
Recently Ive Had A No Start Problem With My 1993 Chevy S10 Blazer. I Recently (last Week) Had A Similar Problem So I Replaced The Spark...
Asked by
jrharv03
1993
CHEVROLET BLAZER
1993 Chevy Blazer Engine Wont Start
W Vin Code Ok Engine Wasnt Getting Spark Changed Plugs Wires Cap Rotor And Coil Ra But Ran Ruff Then It Died Pick Up Coil Was Bad Changed...
Asked by
james1967
1993
CHEVROLET BLAZER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
