1993 Chevy Blazer it will not start 4.3L
LOWRIDER9307
  • 1993 CHEVROLET BLAZER
  • 6 CYL
  • 12,324 MILES
I have a 1993 chevy blazer that has a 4.3L vortce two wheel drive and it is a 4.3L W and it got spark and good gas presure and it will not run all it what to do crank over it has new wire and plues new fuel line and pump I look at the flues and thay are good I had put all the fuel parts that you can. Can you help me
Tuesday, February 26th, 2008 AT 8:26 PM
When you say good pressure-did you check it with a fuel pressure gauge and what was the reading?
Try this spray some carb cleaner into the throttle body and see whether if will start and die. If it does open up the IMTV and inspect the poppet valves and regulator.
Tuesday, February 26th, 2008 AT 8:40 PM
Inbox : Message
To: rasmataz
Posted: Tue Feb 26, 2008 9:38 pm
Subject: 1993 blazer 4.3L
i did that and it start and then dies
Investigate why you're not getting fuel start by checking the actual fuel pressure, then give me the readings. Furthermore, Do you hear the fuel pump come On for 2secs?
Tuesday, February 26th, 2008 AT 9:48 PM
