I know that it is on the firewall, but there are two relays there and I'm not sure which one is for the fuel pump.
Monday, December 31st, 2007 AT 3:22 AM
JUSTGOTMEAJETTA
MEMBER
Well the easiest way to me finding out which relay does which is to remove one, turn your key forward without starting the vehicle and listen for your fuel pump to come on when it does not come on then you have found your fuel pump relay
