1995 Chevrolet Blazer Fuel Pump Voltage Drop Fix
SEAKING
My wife's blazer fuel pump shows 40-45 psi when starting. It will not run. I put a wire to the test lead for the fuel pump and the pressure ran up to 55 psi . I then could run the engine. I started it with the jumper to the test plug and unplugged it after the engine started.
The engine ran fine for 10 minutes or so till I switched it off. Now the jumper has no effect and I am back to 40 psi or so. I put a new relay in and checked the voltage at the relay socket. One leg is hot all the time and another is hot with the key on. At the pump connector with the key on I only get approximately 9 volts.
Nov 3, 2007 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
Check the ground wire, when you use the ALDL to jump the pump you are grounding it...9v should go to 12v when you fix the ground wire..
Nov 3, 2007 at 8:29 AM
BLACKOP555
  • 10,386 POSTS
check the fuel pump relay, and if there still is not 12v at connector then the fuel pump wiring harness could have a bad wire in it somewhere, could be cracked or coroded. i would try a rewiring it myself and see if that provides a better result.
Nov 3, 2007 at 8:31 AM
SEAKING
I put a new relay in and checking the ground on the connector to the body shows no resistance, 0 ohms
Nov 3, 2007 at 8:34 AM
Suggested Repair
With a new relay already installed, inspect and repair the fuel pump power and ground wiring. About 9 volts at the pump connector indicates voltage drop from a corroded, cracked, or high-resistance wire. Repair or rewire the circuit so key-on voltage is about 12 volts.
Conversation Summary
The owner of a 1995 Chevrolet Blazer reported 40-45 psi fuel pressure and a no-run condition. Jumping the fuel pump test lead raised pressure to about 55 psi and let the engine run briefly, but the problem returned. A new relay was installed; one relay terminal was always hot and another was hot with the key on, yet the pump connector showed only about 9 volts. Experts advised checking the pump ground and inspecting or rewiring the harness if voltage stayed low. The owner later measured zero ohms from the connector ground to the body.
