The blazer does have gas and fire at plug wires will turn over but will not start at all installed new plugs to
Monday, November 26th, 2007 AT 6:00 PM
SKYCOP91
MEMBER
Going through same tihing. I've tried new plugs, wires, distributor, ignition coil, and module. Still nothing. Pull your distributor cap, not rotor position, then crank motor for just a sec and see if rotor moved. If not could possiblly be timing chain. If you figure something out before me please keep me informed. Will do the same. I"m thinking it's something very simple but it's driving me crazy.
SPONSORED LINKS
Friday, January 29th, 2021 AT 2:06 PM
CLAYTONANDERSON
MEMBER
That sounds good to me if I find out what it is I will let you know. OK I made some calls about this problem I have I was told to check and see if the timing chain my be worn and it is not firing when it should so I will check that today and see if that is it and let all of you know what I find good luck to all
OK I found the problem the timing chain was bad so I replace it and now it runs
SKYCOP91
MEMBER
Glad to here it. Turned out my plug wires were bad. Had spark through the plug but not strong spark. Replaced the plug wires and wa la.
