Can you hear the fuel pump running when you first turn the key on?
If not then check the relay first and if it has voltage then it is likely the fuel pump is bad.
If you can hear the pump running when you first turn the key on then loosen the line on the left rear (as you face motor from the front) line to see if fuel runs out when you turn key on. If not then check the fuel filter.
Wednesday, November 14th, 2007 AT 10:25 PM
