1991 Chevy Blazer seting timing
JESSE H
  • 1991 CHEVROLET BLAZER
Engine Mechanical problem
1991 Chevy Blazer 6 cyl Four Wheel Drive Automatic
what is the # that you set the timing on it dont have a sticker under the hood or on the radiator
Saturday, August 21st, 2010 AT 5:51 PM
2.8 and 3.1 liter @ 10deg and 4.3 at 0deg
Saturday, August 21st, 2010 AT 5:59 PM
MADMIKE1735
  • 951 POSTS
If its a 4.3 dont forget to unplug the timing advance, located under the carpet on the passenger floor- just beneath the heater core. And it will be 0 degrees TDC. If your not sure where TDC is, look on your harmonic balancer there is a line on it, or you can pull out the #1 cyl sparkplug and hold your finger on the hole while someone bars the engine over. When the pressure pushes your finger off, thats TDC.
Thursday, August 26th, 2010 AT 9:33 PM
