1989 Chevy Blazer engine runs hot
FIKSION
  • 1989 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • MANUAL
  • 14,000 MILES
I have a 1989 chevrolet s-10 blazer recently replaced thermostat and radiator and is still running at about 210 degrees and slowly climbs past I cheecked the water pump as referred by a friend by pinching the hose and feeling it surge as the temperature warmed up and it did is this an effective way to check and is there anything else I should check? Thank you
Friday, March 21st, 2008 AT 8:24 PM
MASTERTECHTIM
  • 4,750 POSTS
How high does the temp go? Have you checked the radiator fan clutch?
Friday, March 21st, 2008 AT 8:38 PM
FIKSION
I always shut it off to cool when it passes 210 in hopes of not damaging the engine. Fan clutch works fine. I am stumped.
Saturday, March 22nd, 2008 AT 11:29 PM
MASTERTECHTIM
  • 4,750 POSTS
You wont over heat until 256. I would watch ato see how high you go. You could have a gauge thats off a little. Remember most vehicles that use electric cooling fans will run until 228 degrees before the fan even comes on.
Sunday, March 23rd, 2008 AT 11:08 AM
