2003 Chevy Blazer can the ac compressor make ur car run hot
2003 CHEVROLET BLAZER
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
2003CHEVYBLAZE
I'm at witts end, on my truck I have changed the radiator, thermostat, 90% of the hoses and the water pump. The thing is my truck still runs hot.. BUT. Only when the AC is on. It won't run hot if I drive in the 90+ degree weather but soon as I cut on the air.. temp goes up till the check engine light comes on.. but there is a twist .. it don't run hot at night.. the temp will rise but just above the half mark. Some people told me to get the AC check..could be low or need a ac cooler thing that's in the front of the coolant raidator, or even the compressor.. its hot in FL need help soon
Aug 21, 2010 at 11:08 AM
LEGITIMATE007
  • 5,121 POSTS
does the vehicle have two fans?
Aug 27, 2010 at 2:53 AM
2003CHEVYBLAZE
No there is one clutch fan and its been replaced
Aug 27, 2010 at 3:34 AM
LEGITIMATE007
  • 5,121 POSTS
have you verified that the fan comes on when you turn the a/c on? because it is supposed to. also you may want to check the engine coolant temperature sensor.
Aug 27, 2010 at 5:36 AM
2003CHEVYBLAZE
Ill check the sensor.. but the cluch fan is on a fan
Aug 27, 2010 at 5:57 AM
