1988 Chevy Blazer oil leak
CHEVYSROCK
  • 1988 CHEVROLET BLAZER
Engine problem
1988 Chevy Blazer 4 cyl Four Wheel Drive Automatic na miles
I have a bad oil leak. It is only bad when going slow or ideling. Could it be the oil sincer?
Sunday, December 16th, 2007 AT 10:20 PM
  • 31,937 POSTS
You will have to wash down the engine and check to see if it is coming from a gasket, seal or oil pressure sender, the sender is a small round screw in fitting with one wire attached (if electrical) or a small oil line.
Mark (mhpautos)
Monday, December 17th, 2007 AT 12:08 AM
