HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Engine
Symptoms
Oil Leak
1995 Chevy Blazer oil leak but not frm oil filter
GMONEY0519
MEMBER
1995 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
163,800 MILES
I dont know where my car is leaking oil from
Thursday, June 19th, 2008 AT 1:53 PM
OBXAUTOMEDIC
MECHANIC
Can you be a little more specific? Were is it wet with oil at. It could be the front seal, vavle cover gaskets, oil sending switch, Intake, rear seal.
I suggest you clean the engine. Then let it run while you look for the leak.
SPONSORED LINKS
Thursday, June 19th, 2008 AT 5:54 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
2004 Chevy Blazer Major Oil Leak
I Just Had My Blazer Serviced By The Local Chevy Dealer. When They Changed The Oil They Said There Was A Major Oil Leak From The Front Of...
Asked by
ddadams444
2004
CHEVROLET BLAZER
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
1988 Blazer S-10 4.3 L Engine Oil Leak
My Blazer Has A Remote Oil Filter Extension Up By The Driver's Side Fender That Is Leaking. It Is Difficult To Tell Whether The Leak Is...
Asked by
matthewz
1 ANSWER
1988
CHEVROLET BLAZER
S-10 Blazer Oil Leak
I Have An 1988 4.3 Tbi Engine. There Is A Decent Oil Leak On Driver's Side. I Can See Oil Running Down An Oil Line. The Filter Is On The...
Asked by
jssjr5591
2010
CHEVROLET BLAZER
1998 Chevy Blazer Oil Leak
Engine Performance Problem 1998 Chevy Blazer 6 Cyl Four Wheel Drive Automatic There Is An Oil Leak Im Not Sure Where Its Coming From...
Asked by
jpray
1 ANSWER
1998
CHEVROLET BLAZER
1988 Chevy Blazer Oil Leak
Engine Problem 1988 Chevy Blazer 4 Cyl Four Wheel Drive Automatic Na Miles I Have A Bad Oil Leak. It Is Only Bad When Going Slow Or...
Asked by
chevysrock
1 ANSWER
1988
CHEVROLET BLAZER
VIEW MORE
SPONSORED LINKS
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
Online car repair manuals
