My blazer has a remote oil filter extension up by the driver's side fender that is leaking. It is difficult to tell whether the leak is coming from the oil filter mount or the oil lines leading to it. At first it looked like it was the seal on the filter that was leaking (the filter was covered in oil) but the leak continued after I replaced the filter. What should I try next?
SPONSORED LINKS
Friday, August 31st, 2007 AT 1:45 PM
