1983 Chevy Blazer Electrical
1983 CHEVROLET BLAZER
BOUGE83
Electrical problem
1983 Chevy Blazer V8 Four Wheel Drive Automatic 120k miles
My truck does absolutely nothing when I turn the key. the ONLY thing that works is the head lights and the dome light. I looked over my wiring, changed my ignition switch, tested my alt and starter. I am stumped. I am open to suggestions and ideas. Thank you
Dec 2, 2007 at 6:23 AM
MERLIN2021
  • 17,250 POSTS
If engine does not crank, check the starter relay, the neutral saftey switch and the starter itself. Try turning the key to on and crossing the S and the large BATTERY cable at the starter, if it starts, replace the starter...Solinoid is NG and it's on a rebuilt...
Dec 2, 2007 at 6:53 AM
