2001 Chevy Blazer Interior dome lights
2001 CHEVROLET BLAZER
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICCOO1
i woke up one morning , went out to start my car and battery was completely dead. I noticed that the wheel switch was pushed all the way forward(dome light switch) i tried to trickle charge battery , but would not take a charge (year old battery). They happily replaced the battery (auto zone) and now my dome lights are stuck on. (dome override will not work) and as far as iknow there is no fuse specifically for the dome lights Only. What do i do
Jan 22, 2010 at 7:53 AM
MIRROCK
  • 22 POSTS
Need to check the door switches that tell the light to come on and off with respect to the opening and closing of the door. If you need iot to drive right away you will need to pull out the fuse marked int lights, (interior lights) You will lose your dash lights with this for the time being until you locat the real problem. The actual switch in the dash that you said was stuck up could be bad too.
Jan 22, 2010 at 8:09 AM
RICCOO1
there is no fuse that says int. lts
Jan 22, 2010 at 11:56 AM
MIRROCK
  • 22 POSTS
Hmm. Well in an effort to help you since i do not happen to know what the interior light label is, i suggest trying to pull one fuse out at a time. You cant hurt anything by doing this. Pull a fuse. See if they go out. If not put the fuse back in and move to the next one till you find the one that makes the dome light go out.
Jan 22, 2010 at 1:50 PM
