Welcome to the forum. There is an interior lamp contol module under the dash, lower center. The only problem, I can't troubleshoot the module, I don't have enough info. At the dome lamp, orange wire is voltage, white wire is ground, I believe. Both wires are connected to lamp module.
Is there a switch under the headlamp switch that says dome lamp? If there is such a switch, it is to stop the dome lamp from coming on, when you open the door.
Jan 7, 2021 at 4:27 AM
(Merged)
