1994 Chevy Beretta I have a 1994 Beretta
CHARLESVANNOY
  • 1994 CHEVROLET BERETTA
Engine Cooling problem
1994 Chevy Beretta 6 cyl Two Wheel Drive Automatic
my beretta over heated an threw a ferzze plug I fix that than I discoverd the fan was not working so I bought a new moter for the fan and I replaced that
im thanking it might be a relay where would that be
do you have any ideads what eles that would be
im a sinlge mom and not much money so please help
thank you
Tuesday, August 11th, 2009 AT 7:37 PM
  • 109,885 POSTS
I take it the new fan isn't turning on. If that is the case, there is a power distribution box under the hood which has relays in it. Open it and there will be a print out on the cover showing what each relay is for. Find the one for the fan. Next remove it and check the part number and locate another relay in the box with the same number and switch them. See if the fan comes on then. If it doesn't let me know and we'll move on.
Monday, December 21st, 2009 AT 10:47 AM
