1991 Chevy Beretta Alternator fuse blows
1991 CHEVROLET BERETTA
290,000 MILES • 6 CYL • FWD • MANUAL
KEVINJR007
My alternator fuse keeps on blowing as soon as I turn the key. I replaced the Alternator. As soon as I turn the key, not to the "Start" but the Accessory position. I'm thinking it could be the starter??? I've even used double the amperage ( 10 amp) fuse and it pops right away. Please help.
Jun 16, 2009 at 6:07 AM
JDL
  • 16,098 POSTS
Hello, with the alternator connector unplugged, does the fuse circuit still go to ground? You can use a testlight across the fuse terminals instead of the fuse.
You can run a B+ jumper from the battery post to the testlight, touch the testlight to the fuse terminal that goes to the alternator, with the connector unplugged, if the light comes on, I think the wiring circuit is shorted to ground, somewhere.
Jun 16, 2009 at 6:45 AM
