IF it happens again, turn the headlights on. If there is a draw the lights will dim when attempting to crank and I would then check for power to the starter solenoid to verify. I dont believe the solenoid is availble separate.
A backyard technique is to tapp on the starter while in the crank position and see if it fires up.
If the lights don't dim, then it may be the switch.
I suspect the former.
Don't buy the cheap ones. For that matter I would only use the napa supreme or the USA brand. Too many defects with others in my experience.
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 7:43 AM
