Hello, the motor to my driver's side window has failed. I have the panels removed exposing the motor.
Can the motor be replaced without removing the entire regulator from the door? I understand there is a very strong counter spring on the regulator. My Haynes manual is unclear on this point, but cautions strongly about this spring.
Many thanks!!!! Randy Jackson, Spring Hill, Florida
May 26, 2008 at 12:13 AM
