1994 Chevy Astro Front Window wiring
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
TABY2007
i need to know if you know the wiring sequence so that i can roll my windows up and down
May 17, 2008 at 8:39 AM
TECHMAN1
  • 82 POSTS
[quote:e85853a8a6="taby2007"]Electrical problem
1994 Chevy Astro 6 cyl Two Wheel Drive Automatic 128000 miles
i need to know if you know the wiring sequence so that i can roll my windows up and down[/quote:e85853a8a6]
Take the white plastic cap off of the window motor and be careful to catch the brushes and springs and the motor shaft rotor, solder a bridge across the temperature switch (which looks like black scotch tape sandwiched between 2 brass tines, reassemble the brushes and springs upside down in a bench vice and stuff the whole thing back into the window motor as one piece and they will work forever.
May 23, 2008 at 3:45 PM
