2001 Chevy Astro 6 cyl All Wheel Drive Automatic 165000 kilometers
During cold weather my vehicle will not start unless I have the block heater plugged in. These are the things that have been done to try and rectify the problem. First, I use gasoline antifreeze when filling up. Replaced the distributor cap and associated parts. Changed the battery to ensure strong cranking. Most recently changed the temperature sensor. When the vehicle is plugged in during the night it will start without hesitation. Is there anything else that may be causing this problem? Thank you.
SPONSORED LINKS
Friday, February 8th, 2008 AT 12:43 PM
